Two 200 amp disconnect main
I have four green house and I want to pull a 100 amp to each greenhouse from the two 200 amp main service disconnect. What should I do? Should I just buy four 100 amp circuit breaker and run that to my subpanel?
The neutrals of the main panels should terminate in their proper location in each panel. (one wire per panel)
Both main panels should be bonded together but can be connected to the grounding electrode using a single grounding electrode conductor.
