Load balancing a main panel?
I'm seeking guidance here. Thank you in advance!
I am wanting to check the load balance on my main panel. What meter would you recommend? And is there a way to check the load balance over a set period of time, say 24/48 hours? I can check the load balance as a "snapshot" of whatever is turned on at the moment, but with things being turned on/off throughout the day ..... I wonder how accurate that "snapshot" would really be?
Thanks again!
Thanks again!
Best way to monitor would be using IoT energy meter of some kind. There are several out there.
Like joed said, there really is no reason to load balance in residential setup as loads will change through out the day and most high current devices are on 240V.
Sorry to be the bearer of bad news BUT- you don't get "free" electricity by "balancing" the load.
In most cases, "load balancing" means something quite different, it refers to re-wiring heavily branched circuits that are over loaded, so that the "branches" are wired into adjacent lightly used circuits. This is mainly to avoid the "old house wiring" problem where plugging in a hair dryer in the bathroom trips the original 1930's 'whole house" circuit and all the ceiling lights throughout the house go dark.
(Backstory- early wiring was mostly for ceiling lights. MANY pre-WWII homes retain that initial circuit, which usually supplies 1 ceiling light in each room, and then have other circuits which were wired in later.
There's already a "why this won't work" thread pinned somewhere.
home electrical balancing - DoItYourself.com Community Forums
You should load balance a bit, not by measuring but by estimating average load.
ignore all the two pole breakers since they are balanced on each leg but mostly just balance out the 15A breakers.
In practice, if you have say 10 15a breakers you can put 5 on one side 5 on the other leg.
A better estimate takes into account what you're using on each of the circuits.
Lambition, is an IoT a 24 hour recording device? It is what the poster wants versus a meter than only yields an instantaneous reading. Does an IoT require some temporary rewiring of the circuit to be measured? I am not familiar with them.
Here's an example of a power monitoring/recording device:
https://sense.com/
It uses clamp-on ammeters, connects to your wifi, and phone apps to monitor your power usage throughout the day. You can get all sorts of reports.
There are a bunch of similar systems out there - I haven't used any enough to be able to recommend any one over the other. There are some that monitor each circuit individually, and others that estimate based on total load.
https://sense.com/
