Breaker not tripping - defective?
Old 04-28-21, 09:45 AM
Hello all, new guy here. Hoping for some insight.
I recently realized my GE electric oven/microwave combo was on the same circuit as my Whirlpool electric range top w/ downdraft blower. The combo is rated at 30A (model number JK3800SHSS) and the range top is rated to 40A (model number KCED600GBL).
The fact these totaled 70A on a 50A breaker alarmed me. To test, I turned on all cooktops, the blower, the oven, and the microwave expecting it to trip. It did not!
Question: Why would this be the case and should I be worried about a defective breaker?
Thank you for any help you can provide!
Sam
Old 04-28-21, 04:18 PM
Received 38 Votes on 36 Posts
No not yet breakers have thermal & magnetic trip mechanisms the magnetic is instantaneous and usually only trips from a direct short of hot to hot or any hot to the neutral or ground (if it has one EX: not an older 3-wire circuit) the thermal is time based known as a trip curve the amount of time depends on how great the overload is this is done to allow things with motors to start without tripping immediately.
Make & model of panel and a picture would be helpful also.
Sam Mays voted this post useful.
Old 04-28-21, 06:26 PM
Tolyn Ironhand's Avatar
Received 369 Votes on 319 Posts
How are you measuring the current draw? Are you just going off the nameplate?
Old 04-29-21, 07:40 AM
Thank you for the replies!!! A couple answers below...
I didn't know the time-dependent thermal trip. Thanks! Picture of the panel attached.
I'm going off the nameplate/specs. So I don't have a measured current draw, but I figured (perhaps wrongly) that if I turned on the highest load of every item (oven broiler, highest microwave power, highest setting for all burners, highest blower setting) then I would at least hit the 50A break point.
Old 04-30-21, 04:37 PM
Nope. The 50A is only the rating of the breaker which is sized by the wire installed. Running everything on the stove at full tilt I would be surprised if it was drawing more than 40 amps
CasualJoe voted this post useful.
