NEC restriction on an outlet near a water source???
Old 04-28-21, 12:45 PM
Exclamation NEC restriction on an outlet near a water source???
In my basement project, I want to place 120V and 24V receptacles in a spot that is also near [about 12"] from a water tap. It's where I need them.
The 120V circuit will be on a GFCI which fits the 6 foot rule. No easy way to do that for the 240V w/a GFCI receptacle that I know of. Is a GFCI circuit breaker doable to meet code? Is there another way and/or cheaper way?
Thanks guys!
Old 04-28-21, 01:52 PM
Geochurchi's Avatar
Received 96 Votes on 89 Posts
Hi, a 2 pole GFCI breaker would be fine.
Geo 🇺🇸
Old 04-28-21, 06:23 PM
Tolyn Ironhand's Avatar
Received 371 Votes on 321 Posts
Depending on your location, and what code cycle you are on, GFCI protection may not be required for a 240-volt receptacle. That requirement was added in the 2020 version of the NEC.
Old 04-28-21, 08:08 PM
Thanks guys!
Interesting point about the code cycle. When I submit the permit I'll ask.
Old 04-29-21, 06:22 AM
I
Received 24 Votes on 19 Posts
I'd do the GFI breaker anyway, even if not required. Staying alive is worth a few bucks, ya know.
Old 04-29-21, 12:55 PM
P
Received 157 Votes on 129 Posts
I believe if the basement area is unfinished(basically bare concrete floor) NEC requires GFCI protection for receptacles.
Old 04-30-21, 04:15 PM
2020 NEC requires all receptacles located in a basement to be GFCI protected regardless if it is finished or not.
