Multiple outlets of different voltages
Old 05-02-21, 09:55 AM
D
Can you supply a 120V and 240V outlets from a single 220V circuit? I have a freezer that requires both and was thinking I can supply that from a single 220 V circuit breaker.
Old 05-02-21, 10:06 AM
A
Received 134 Votes on 123 Posts
Technically yes. Run (for 20 amps) 12-3 Romex cable to the double wide doulbe breaker.. At the other end onnect red and white or black and white to a 120 volt receptacle. Connect red and black for 240 volts only. Connect all wires for a 120/240 volt (dual voltage) receptacle.
Caution: Do not use ordinary 120 volt (only) receptacles for 240 volts or 240 volt only (3 prong including ground) for 120 volts.
I would have thought that your freezer would have one 4 prong plug instead of separate 120 volt and 240 volt plugs.
Old 05-02-21, 10:44 AM
L
Received 15 Votes on 11 Posts
The answer is yes, but the real answer is to hook it up exactly as the manufacturer says.
Old 05-02-21, 10:56 AM
Tolyn Ironhand's Avatar
Received 352 Votes on 304 Posts
It depends on what the two loads are. I have never seen a freezer that requires 208-240V. Is this a commercial appliance?
Old 05-02-21, 06:10 PM
D
Here is the manufacturer's label
Old 05-02-21, 07:10 PM
L
Did it come with a cord or will you be adding one? I'm a little concerned that you said outlets plural, since surely there will be only one cord (e.g. NEMA 14-30)?
Old 05-02-21, 07:25 PM
Received 326 Votes on 281 Posts
Are you sure that unit needs two voltages. It looks to me like it can use one or the other.
Old 05-02-21, 07:28 PM
P
Received 150 Votes on 123 Posts
The freezer doesn't require both 110V and 220V. It uses one or the other depending on how you wire it.
Old 05-03-21, 11:01 PM
Received 38 Votes on 36 Posts
It has two compressor known as a cascaede fridge one usually is smaller and needs 120VAC and the other needs 240VAC very common for commercial stuff.
