Outlet Getting Power but not delivering power
I am replacing a GFCI on a porch. After wiring, it would not provide any power from the plug. I tested the terminals on the outlet with a MM and it read 120. Inserting the leads from the MM into the outlet showed no volts and a GFCI tester plug showed no power.
I am at a loss.
I am at a loss.
Top Answer
06-14-21, 09:57 PM
Welcome to the forums.
After installing a GFI receptacle.... you need to push the RESET button.
The receptacle needs power in order for the reset button to work.
CasualJoe,
ThisOldMan
voted this post useful.
