Reload this Page >
Can I install an outdoor outlet sticking up from the ground with no support?
Old 01-22-22, 09:26 AM
N
I'd like to pour a concrete slab in my backyard for my bbq. I'd like to have power available there. The simplest solution would be to run UF-B to the slab, bring it up through the slab in a conduit, and stick a weatherproof outlet box on the conduit 2" or so above the slab surface.
This is what I would like to do, knowing that when the grill is in place it will be a physical barrier to tripping over the outlet, but I'm not too sure that this arrangement would sit well with the Powers That Be. Without a grill present, this could be a tripping hazard and I don't know what the rules and regs are about something like that.
What's the simplest way to install an outlet on a concrete slab I'm about to pour?
Old 01-22-22, 09:33 AM
Received 475 Upvotes on 391 Posts
Not sure if it is allowed, but if it is, I would for sure use RMT (heavy pipe) type conduit, not EMT or PVC.
2john02458 voted this post useful.
Old 01-22-22, 04:20 PM
A
Received 83 Upvotes on 75 Posts
Best to have a short wall or something else solid to mount the box to. Otherwise you need two threaded conduits to support a box.
https://img.ecmweb.com/files/base/eb...56&w=1000&q=60
CasualJoe voted this post useful.
Old 01-25-22, 09:42 AM
pcboss's Avatar
Received 163 Upvotes on 142 Posts
Darn, what a price premium over supply house prices for the Garden post.
Old 02-01-22, 07:42 AM
T
Received 71 Upvotes on 66 Posts
I would do a stainless unistrut with pvc conduit.
Old 01-22-22, 09:51 AM
Marq1's Avatar
Received 1,061 Upvotes on 963 Posts
Old 01-22-22, 02:39 PM
Received 3,338 Upvotes on 2,997 Posts
Although it's a great idea Marq..... an outside floor pocket would be a headache forever.
A weatherproof box on a short stub of 3/4" galvanized pipe would work fine.
The galvanized pipe is just a sleeve for the UF cable.
Old 01-22-22, 02:49 PM
XSleeper's Avatar
Received 1,645 Upvotes on 1,473 Posts
I've also seen posts (treated wood or even a capped aluminum post) put into the ground for the conduit to strap to. It's a little more durable that way if it gets bumped.
Old 01-22-22, 02:53 PM
Marq1's Avatar
I don't disagree, was kind of surprised to find one.
I would try to incorporate something in a vertical wall, something part of the patio/deck!
Old 01-23-22, 08:04 AM
Geochurchi's Avatar
Received 158 Upvotes on 144 Posts
Hi, this could be an option, bury it so that the opening is below the slab for access latter, also if you use the conduit route I would use 2 conduit stubs , 1 for support and and to keep it from turning the other for the cable.
sorry I copy the link , I’ll something else.
Geo🇺🇸
Old 01-23-22, 03:49 PM
CasualJoe's Avatar
Received 172 Upvotes on 155 Posts
Remember that the UF-B cable cannot enter the slab without being in conduit.
Old 02-03-22, 03:58 PM
CasualJoe's Avatar
Stainless strut might be hard to find without ordering a 10 foot stick. Galvanized strut would be fine.
