3 plug 240 volts 30 amps to 4 plug 60 amps
Old 06-30-01, 06:17 PM
Guest
would like to know how would you change a 3 plug 240 volts outlet 30 amps to a 4 plug outlet 240 volts 60 amps.
Old 06-30-01, 08:08 PM
In general, you can't.
The answer to your question is the same if you'd asked how to completely remove one circuit from receptacle to the breaker, and to add a new circuit. You need to remove the breaker, remove the cable (actually optional), remove the receptacle. Then install a new breaker, install new cable (larger and with more wires), and install a new receptacle.
