Running power from garage to shed
Old 08-10-22, 03:10 PM
I am running a 20 Amp dedicated circuit to the shed in rigid conduit 6+" deep. I have a weatherproof mounted to the LB conduit body outside of the garage.
I ran 12ga THWN wires from the shed to the LB conduit body Can indoor Romex be in the LB conduit body on the outside of the garage Or what are my options? I am going to use romex from the panel in the garage.
Thanks
Old 08-10-22, 03:17 PM
Received 2,957 Votes on 2,668 Posts
You can use NM-b from the LB to inside.
There cannot be any NM-b used outside.... in conduit or not in conduit.
Best to run separate conductors but if you want to run a cable.... use #12 UF.
Old 08-10-22, 07:44 PM
Tolyn Ironhand's Avatar
Received 595 Votes on 511 Posts
LBs are quite small and only some are allowed to splice in. I would recommend using an outdoor-rated metal box instead of an LB. Another option is to run an RMC nipple into the building and connect it to a 4x4" steel box. You are also required to bond the ground to the steel conduit if it is not run continuously between pull points.
Old 08-11-22, 02:30 AM
Marq1's Avatar
Received 950 Votes on 862 Posts
Isn't the requirement for buried conduit 18" deep?
Old 08-11-22, 07:50 AM
P
Received 210 Votes on 178 Posts
RMC can be 6".
