Light Switch to control a ceiling instalation
Old 07-06-01, 09:04 AM
Guest
I want to convert a light switch that controls a wall outlet to use the switch to control power to a ceiling fan. I have successfully undone the wiring to the switched outlet and replaced it so that both sides of the outlet are now "hot". The switch is disconnected and controls nothing. I have run 14/2 from the ceiling fan to an area proximate to the switch wiring in the attic and I have a source of power at the same place.
I'm just not sure how to connect the blacks and whites so that the power to the fan is controlled from the switch. i will then control the light and fan from the pull chains.
Thanks for your help!
Old 07-06-01, 10:12 AM
Guest
This is my concept-You dis-connected a 2-wire switch leg at the switched receptacle-at the switch there is only a Black & White,both dead-the 2-wire cable between the switch and receptacle is accessible in the attic-in the attic you will cut this cable and bring the end going to the switch into a splice-box.If this is correct then; cover the White wire at the switch an in the attic splice box with Black tape-bring the 2-wire from the faninto the splice box-wire nut the Black from the fan to the wire taped Black which leaves a Black and White which will connect to the Black and White of a 2-wire feed.Bring the end ot the cable that goes to the receptacle into the splice box and at the receptacle you can re-connect it for the feed.
Old 07-06-01, 11:38 AM
RickM
Cool
If this was me doing this job, I would take, along with the switc leg (for the light) a hot wire, to connect to the fan. Then, no matter what the switch was set at (on or off) I could still control the fan, via the pull chain. Doing it any other way will cause frustration. Believe me. I did a setup just like you want to do, in my bedroom, and I am not pleased with the result. Run the 3rd wire.
Rick Miell
Old 07-06-01, 05:13 PM
raca
You shoulda ran a 3wire right to the switched outlet it woulda been ten times easier and faster.
