Reload this Page >
Installing new 240v cooktop but wire colors are different on house
Old 09-09-22, 01:11 PM
T
Hello,
I have an older jenair 120v/240v electric cooktop i'm currently replacing. I have bought a 240v cooktop as seen here
https://www.homedepot.com/p/GE-Profi...67de12bf94a369
House Wires in junction box
white + black + copper ground wire
The older cooktop
The older cooktop had a black + white + red wire.
black (from the cooktop ) -> black ( on the house )
red (from cooktop ) -> white ( on the house )
white (from cooktop ) -> copper ground ( on the house )
The new cooktop
The new cooktop has the following color wires
1 green
1 red
1 black
What colors do i hook these to on the house wires? So far i have
black (from the cooktop ) -> black (from house)
red (from cooktop) -> white ( from house )
green (from the cooktop ) -> copper ground ( on the house )
Is this correct?
Old 09-09-22, 01:26 PM
T
these instructions were connected to the cooktop wires
Old 09-09-22, 01:31 PM
P
You got it right. The old cook top was using the ground as neutral to get 120V.
You should re-identify/tape the house white as red.
The following users liked this post:
Old 09-09-22, 01:48 PM
T
Hey @pattenp,
We turned it on and sure enough it's working.
Thanks!
Old 09-09-22, 07:30 PM
L
FYI. Your new cooktop is actually 240V only. So, it won't be using ground as neutral.
White wire is supposed to be marked black, red or blue to show it is used as hot, but I never seen that actually done unless it is getting inspected.
Old 09-09-22, 09:35 PM
T
We just noticed that our 240v whirlpool double oven has switched to "control lock mode" and says swipe up to exit but never exits. The double oven has power except we cannot do anything with it since it wont exit control lock mode. The cooktop ( which is on the same circuit ) is working fine.
If something was hooked up wrong i wonder if this could cause this??
Old 09-09-22, 09:58 PM
L
Your oven issue is completely unrelated to cooktop. They are (at least supposed to be) wired in different circuits.
Is touch screen not working at all or just not exiting control lock mode?
Try power cycling by turning breaker off and back on. If that doesn't work, something may be wrong with control board or touch screen.
Old 09-09-22, 10:01 PM
T
It's just not exiting control lock mode
I turned off the breaker for 1 minute and even 5 minutes to do a hard reset but still not lock. The whole oven touch screen is functionining but i cannot do anything because it wont exit control mode when i slide up like it mentions....the slide up effect is happening but it's still stuck in the lock mode which means no other buttons work.
It has also switched to spanish for some reason....
Old 09-09-22, 10:06 PM
T
pictures of control lock
Old 09-09-22, 10:08 PM
T
Somehow this didn't upload on the first post in this thread but This is what the new cooktop hooked up looks like
This is the old cooktop unplugged and on the island
Old cook top unplugged
s wasn't uploaded before but here is how i ended up hooking up the wires as described in the previous post
Old 09-09-22, 10:11 PM
L
https://www.youtube.com/watch?v=UPiYA7ZeLuA
This is what you are doing, but doesn't work. Right?
Maybe top portion of touch screen is not working, not allowing you to fully swipe up?
I suggest calling Whirlpool technical support. You might have to have service tech come out and possibly have to replace control board.
You need to properly secure that cable to the junction box and cover. Cannot just leave splice outside of the box like that.
Remove 90" connector from your old cook top, and get octagon box cover with knock out.
https://www.homedepot.com/p/RACO-4-i...-724/202056189
You might have to get a nut for the connector if you didn't have one with old cooktop.
Old 09-09-22, 10:29 PM
T
I did indeed do this afterwords. Just took the picture like this so we could post on the forum
We did do this as well
It had one
Yea i think this is what we need to do. The swipe is actually working and the action is completing but it just stays in lock mode We are doing it exactly like the video you posted of https://www.youtube.com/watch?v=UPiYA7ZeLuA
Old 09-13-22, 09:25 AM
CasualJoe's Avatar
That wouldn't be the same breaker as the cooktop, would it?
The older cooktop
I wouldn't worry about it now, but FYI the Jenn Air cooktop was not properly connected, it was a major code violation because you were using a bare ground wire from a NM cable as a current carrying neutral conductor.
Old 09-17-22, 01:26 PM
T
Yes it's the same breaker as the cooktop. Both the cooktop and the double oven were on the same circuit/breaker
