Homeline panel - No 10 amp breakers available
Old 09-19-22, 08:19 AM
Z
Hello, I've just purchased some Pioneer HVAC equipment to have installed and we are prepping the electrical for the installer and noticed that the new air handler is super efficient and requires a max breaker of 10amp. The problem is that Homeline doesn't make a 10 amp double pole breaker. Anyone have any ideas?
Old 09-19-22, 08:20 AM
T
If 10Amp is in the install manual, then you may be forced into a fused disconnect, using FRN10's or similar cartridge fuses.
Old 09-19-22, 08:51 AM
L
I doubt 10A is correct...is that really the "max fuse" rating?
Old 09-19-22, 09:01 AM
Z
Thanks telecom guy - I was thinking the same thing.
Luke M , its correct. Here is the name plate:
Old 09-19-22, 09:06 AM
L
You could use two 10a breakers with a handle tie.
https://www.homedepot.com/p/Square-D...HTCP/100202283
Old 09-19-22, 09:15 AM
Z
Luke M so Square D doesn't even make/offer any 10 amp breakers for Homeline panels - single or double pole
Old 09-19-22, 09:26 AM
L
You're right again. So there's no way around it, you have to install another box with either fuses or breakers (10a breakers do exist, even Square D makes them, just not Homeline).
Old 09-19-22, 09:36 AM
L
Do they make a 120V version of this unit? That would save panel space and maybe allow a 15a breaker to be used.
Old 09-20-22, 06:58 PM
L
With hardwired installation, you are allowed to use next size up breaker if required breaker is non-standard size.
Installing 15A breaker with 14AWG cable will be ok.
I could install fused service disconnect with 10A fuses if you want to meet what the manufacturer specifies.
10A rating is probably because it was designed for 220V-230V market like Europe. 10A or smaller breaker is common in those markets.
The following users liked this post:
Old 09-20-22, 07:46 PM
Tolyn Ironhand's Avatar
Per the NEC, 10 amps breakers and fuses are not a "standard rating" per table 240.6(A). They do make 10 amp fuses as they are part of the "additional standard" ratings. Your only option is to use a 15 amp 2 pole breaker in the panel, at least 14 gauge wire/cable, and a fused disconnect with 10 amp fuses at the unit.
Old 09-20-22, 07:51 PM
P
It's not a sizing breaker to wire requirement. It's using the specified max breaker/fuse size stated by the manufacturer of the unit to be code compliant.
Old 09-27-22, 09:27 AM
CasualJoe's Avatar
I see the problem right on the label. Look again and you'll also see "Made in China".
