how to replace 50s fridge outlet?
pulled out the fridge because replacement coming tuesday. always had this outlet there. assumed original from the 50s. you can see it's weird where the wire comes down fed from the cabinet then they sorta put it in the wall a weird way.
the other electrical you are seeing is an outlet thats in the cabinet above the fridge. no clue why you would put one there. very weird. that outlet is properly grounded per my plug in tester.
i'm not good with electric but i read online if you take your meter and put one lead in the smaller slot on the 2 prong outlet, and the other prong on a screw, and it registers, then it's grounded with the box.i guess? it did register so i guess it's grounded
i dont know if it's smart to try to replace something like this now or not or just keep running the new fridge off the 3 prong adapter. it's a weird 'box' to replace and unsure what will happen when i take it off/apart. should i put in gfci?
for a moment i thought about feeding the fridge up to the cabinet outlet but i am betting it's on the same circuit as my microwave (and other counter outlets) and thats why someone ran a line separate for the fridge. also i cannot run new lines because the only access is a crawlspace which i really cant get into. .
Top Answer
10-01-22, 05:42 PM
That's an old recessed clock receptacle. It was probably used back there because of limited clearance but a fridge should never be buried flat against the wall. You should definitely replace that with a new grounded duplex receptacle.
There will be a standard electrical box behind that plate.
I would not recommend using a GFI receptacle there.
You could sell that plate as "vintage" on ebay...... vintage clock hanger outlet by Eagle
Yes, that's a *bit* of a kludge! You want a properly grounded 3 prong receptacle there. Shut off the power, take the cover off and pull the old receptacle out and take some more pics. Folks here can help you get what you need.
I would recommend correctly bonding the ground to the metal box and installing a grounded outlet.
CasualJoe
voted this post useful.
so is that bare wire what needs screwed into both the box and then attached to a new outlet? i have spare outlets to easily do this then
If the refrigerator has an angled plug, is the receptacle oriented so that the cord can hang down when plugged in?
Also we cannot see the legend on your tester so we can only assume that the correct lights are showing for a properly grounded and polarized connection.
reversed it soon as i saw that.
def correct lights. party time! also found out that that breaker controls only one ceiling light and my range hood. the house was really wired poorly! also discovered during a reno that the 2 bedrooms and bathroom are all on one breaker. genius!
PJmax
Or give it to me as I collect those vintage electric parts but his appears to be missing the hook so not much use as a clock hanger anymore though.
I think current code calls for a dedicated outlet for refrigerator.
fridge doesnt work. unsure it ever worked..sigh. they took forever to install the 'wrong' water line and it was after 5 when they left and i just assumed it would take over night to cool down. well it is still 60. no sounds at all. i figure i should hear or feel some kind of airflow..sigh
ive turned off breaker a few times and adjusted the temps.nada..so they get a call at 8 am.
.091 kwh is what the app says was used every hour over night. consistently. which means i assume no compressor ever turned on. they called and said will be out today. i hope it's some magical button they forgot to turn on. very frustrating.
hope has nothign to do with my new outlet, especially since it tested Ok ground hooked up correctly.
im not home but was told no freon = no cool fridge
new one coming friday. my gf said we dont want the current one filled...who knows what else would be wrong with it. who forgets to put in freon!!!
thankfully this was a popular model in stock by a local dealer i do business with. i'll be SURE this time to make sure it blows cold before the delivery guys leave. sure hope isnt the same ones that were here yesterday though
#23
yes 20 each. just what was laying around. too bad didnt need a light switch cover. have tons of them
#24
new fridge installed. is down to 56 within 30 min of them leaving , they said they ran it last night down to temp. looks like i got a good one. so happy!
also glad it was here today. my contractor came to finalize kitchen island planning and having that fridge installed made it perfect for measurements.
#25
overnight it was set at 36 but only got down to 40 so I must play with temperature a bit more
