Running wire through PVC conduit outdoors
I have an existing outdoor ceiling box that I would like to branch off to a new box (for a floodlight) approximately 4’ away. Both boxes have 1/2 threaded holes. Can I run 3-wire sheathed cable through 1/2” PVC conduit or must I run separate wires only? Does the sheathed cable and the conduit diameter cause an overheating concern? Thanks in advance!
You can run sheathed cable, however, you cannot run NM-b (aka Romex) outside even if it is in conduit.
You can use UF-b cable or THWN wires instead. You can buy THWN by foot at hardware stores, so it probably is easiest.
Conduit between the two boxes will probably look the neatest.
You'd need to run three separate wires (THWN-THHN) or you could use 14-2 w/gr UF cable.
You could also use just 14-2 w/gr UF and no conduit.
Either way would be acceptable.
Thank you PJmax and lambition! The electrical boxes are mounted to steel plates which are mounted to the underside of a corrugated steel concrete pan between two "legs" of the pan (second story balcony installing lights and ceiling fan on the underside). The span between the two boxes is approximately 4' in the same channel of the steel corrugated pan. Can I install 4' of outdoor PVC conduit without having to secure it to the ceiling? In other words, connected to the two electrical boxes but not anchored. With my electrical boxes I can use either 3/4 or 1/2 PVC, should rigidity matter. I thought I read somewhere that suspended PVC requires anchoring every 3', is this correct?
PVC would droop in the middle if not fastened.
You could use metal EMT.
Easy to work with and looks nicer than PVC. (also paintable).
Comes in 10' length. You'd need two EMT connectors.
1/2" EMT compression connectors
10' 1/2" EMT
10' 1/2" EMT
