Feit outlet
Feit outlet
Hi, anyone experience this issue when connecting to WiFi , pairing light on units do not stay lit and won’t program, new unit from customer service performs the same way .
Geo🇺🇸
Geo🇺🇸
The lights usually flash while pairing. Is that what you mean by “not staying lit”? There are usually two methods to pair. Do your instructions offer a direct connection where the plug broadcasts it’s own network and you select it in Settings instead of your home network. After setup that way it uses the home network.
Geo.... are you using the Feit Electric app on your phone to set the modules up ?
Feit electric plug manual
Yes, I am using the app, problem seems to be that in the pairing mode the LED stops flashing before the device is paired.
Pete, I will look that manual over a bit, easier reading then the one it came with.
Geo🇺🇸
Geo🇺🇸
