slow down speed of AC FanCoil blower motor
Old 03-21-23, 09:03 AM
I
hello, i have a central AC Fan Coil with a 3 speed motor within my Condominium. I run the fan of low but find it blows too much air and produces too much noise when i run the AC (the motor works perfectly and doesnt make noise internally, just the rotation and airflow it produces for my samll condo unit) i just dont want to hear the central ac fan running so loud when ac is on
my question is what can i do to control/lower the speed of the blower motor (again, its a 3 speed motor and I only run it on low)
would adding a resistor inline do the trick? is there a device that can run between my 120Volt wire and the low speed wire on my blower motor?
its a 120Volt, 1/5 HP 3 speed ECM motor
any ideas would be appreciated
Old 03-21-23, 09:47 AM
P
Received 1,849 Upvotes on 1,655 Posts
I would seriously reconsider slowing below your lowest setting. It can damage or cause problems when there is insufficient airflow through the unit. It's less an issue with a gas or oil furnace but heat pumps and AC can freeze up if you don't keep enough air moving through it.
Old 03-21-23, 10:41 AM
Received 3,485 Upvotes on 3,128 Posts
An FCU typically uses cold water supplied by a central chiller for cooling.
There is no way to slow down an ECM motor below it's programmed setting without having the control module reprogrammed.
Old 03-21-23, 11:06 AM
I
I made a mistake, the motor is a PSC motor.
my condo has a chiller plant in the basement and pumps the cold water to my condo unit with a supply water line that connects to my FanCoil Unit and there is also a return water line from my FCU...
but the fancoil and motor is mine and connected to the apartments electric, i can cut off power to the motor by a dedicated AC circuit breaker
when you say "control module reporgrammed" I assume your talking about ECM. I made a mistake i have a PSC motor.
Old 03-21-23, 11:27 AM
Correct.
Not really much of a way to slow down a PSC motor either.
You want to go slower than the low speed tap.
Just reducing voltage to that motor will cause it to overheat.
That would require a VFD (variable frequency drive).
It's an electronic phase shifter to change motor speed by varying the operating frequency.
I'm looking for a cost effective unit. They typically start at $100.
Old 03-21-23, 11:50 AM
I
thanks for the reply. would something like this be suitable, or does it need to be more specific for this motor or application? if its not suitable can you post a recommended version...
https://hdsupplysolutions.com/p/kbel...xoCBt8QAvD_BwE
Old 03-21-23, 12:34 PM
That device says ok for PSC motors of up to 6A.
Just make sure your motor is under 6A.
ilcaa72 voted this post useful.
Old 03-21-23, 02:24 PM
I
question, this motor has a capacitor. how would that effect the interaction between this device and the initial starting of the fan coil motor? ( i only plan to reduce speed by 20-30%,,, of lowest speed available on motor)
Old 03-21-23, 02:58 PM
I
here are some details of the link i posted...
About this item
  • Designed for Standard 2" x 4" Electrical Wall Box
  • 5.0 Max amps 115 Volts; UL & CSA Approved
  • Not to be used with Capacitor Start or Capacitor Run Motors. Note: Not to be used with gear motors
  • Applications: Fans, Blowers, Fireplace Blowers, Attic Fans, Humidifiers, Ventilators
does it make it unusable for me.... another option?
Old 03-22-23, 08:37 AM
I
i spoke to KBElectronics that makes the above Vari-Speed control. They have a device that works with Capacitor motors.... max rating is 3AMPs... but it works for me
KBMC-13BV (H9034) Solid State AC Control
https://www.kb-controls.com/product.sc?productId=106
Old 03-22-23, 07:41 PM
L
Received 181 Upvotes on 155 Posts
Have you considered replacing motor with slower one?
If there is slower motor with same physical dimensions, it might be the cheapest option.
Old 03-23-23, 01:47 PM
I doubt that will work. Ask them if you can send it back if it doesn't work.
I wouldn't expect much for $12.
CircuitBreaker voted this post useful.
