Running underground wire to shed
Old 03-25-23, 09:24 AM
C
This is for a roughly 40 foot run from my house to my shed. I know code says at my 2-foot trench depth I don't need conduit, but I'd like to put my wire in conduit anyways.
I'm running 100Amp, 240VAC, so I need 3 conductors + 1 ground at 1AWG. Should I just buy 4 lengths of single-wire 1AWG THWN? Or is there a better way?
Top Answer
03-25-23, 02:09 PM
Tolyn Ironhand's Avatar
Tolyn Ironhand
Tolyn Ironhand is online now
Received 712 Upvotes on 605 Posts
If you are running PVC conduit you only need to dig 18" down.
For 100 amps you need to run #3 copper or #1 aluminum for the two hots and neutral wires. The ground can be #8 copper or #6 aluminum.
I would only recommend running individual wires in conduit. THWN copper or XHHW aluminum.
Old 03-25-23, 11:00 AM
Marq1's Avatar
Received 1,145 Upvotes on 1,038 Posts
When I wired my 50 Amp spa they were all single wires, I do not believe there is any other option especially if your trying to pull that through conduit!
Old 03-25-23, 02:09 PM
CasualJoe, Zorfdt voted this post useful.
Old 03-25-23, 04:41 PM
Z
Received 372 Upvotes on 332 Posts
At that size (anything over #6) you can re-identify the wires.
So you can purchase 120' of black wire, cut in 3 pieces and mark one as white/neutral. You could also purchase 160' and cut it in 4 and mark one white and one green - but it may be cheaper to downsize the ground as Tolyn mentioned.
(Obviously purchase some extra so you don't run short. Cable stretchers are hard to find! (joke)
Old 03-25-23, 06:44 PM
P
Received 243 Upvotes on 207 Posts
Technically buried PVC conduit by the NEC requires 18" of cover, so that means the trench needs to be a few inches deeper than 18".
