Wiring concealment alongside an exterior deck
Old 05-20-23, 02:21 PM
A
Received 2 Upvotes on 2 Posts
The picture below shows an electrical cable lying on the ground, alongside a composite material deck. The end of the cable terminates in an electrical outlet. Note that there's not much working space (8" or less) for the last few feet of the cable run. My intent is to conceal the cable and not have it hanging loose. What are my options?
Old 05-21-23, 07:48 AM
T
Received 160 Upvotes on 139 Posts
The answer may depend on the cable type. Check along its length for markings like NM, NM-B or UF.
Old 05-21-23, 11:13 AM
A
While most cables are marked along their length, this cable doesn't have such markings. What I can tell you is that within the exterior plastic sheathing is contained 3 insulated wires - white, black and green. I've also attached a pic of the cable terminating into an outlet pair, which is mounted on a deck pillar.
Old 05-23-23, 02:32 PM
A
My thinking is to pass the cable through a 6' x 1/2"conduit and hang the conduit on the fascia, secured by straps, utilizing existing fascia screws to fasten the straps to the fascia board. As an example, see attached pic.
Old 05-24-23, 05:56 AM
T
I would guess that the cable type is NM or NM-B (commonly known as Romex) and the marking has faded from exposure to sunlight. Neither of those cable types is rated for outdoor use, including in conduit. If you sleeve it, be careful sliding the conduit over the wire; you con't want to damage the sheath on the cable.
Old 05-24-23, 09:15 AM
A
Thanks for the caution. In reality this cable is an extension cord (see picture, orange plug) that runs from the basement out to the deck. It is not hard-wired to the main electrical panel. It had been in place for many years with the cable stapled to the side of a wooden deck. There had been no issues with this arrangement, with the ability to unplug it at any time. After the deck was converted to composite material, I don't consider the use of staples a good option. All I'd like to do is tuck it away so that it doesn't become a tripping hazard and looks half-way neat even if not completely concealed.
Old 05-24-23, 01:55 PM
Received 3,485 Upvotes on 3,128 Posts
In the first and last pictures.... that is UF cable. It's designed to be used outside.
Most UF cables have a bare ground wire. Some have an insulated one but that is rare.
You can use 1/2" PVC pipe as a mechanical holder.
Plugging the UF cable in to a receptacle using a plug is not code acceptable.
CasualJoe voted this post useful.
Old 05-25-23, 03:18 AM
pcboss's Avatar
Received 167 Upvotes on 146 Posts
While it has been working for years, it was never code compliant on several aspects. Replacing it with the correct materials is your best solution.
Old 05-25-23, 04:52 AM
Tolyn Ironhand's Avatar
Received 708 Upvotes on 601 Posts
Ideally, the cable should have been run between the joists before the decking was put on, and then PVC conduit up the post to the receptacle. At this point, the best option might be just fishing the cable between the joists over to the post location.
Old 05-26-23, 11:16 AM
B
Received 3 Upvotes on 3 Posts
Have you considered a Cable Raceway rated for exterior use, here, tuck it right under the lip of the first step.
As for the plug check this out here.
Old 05-28-23, 12:54 PM
A
Guys, thanks for all of your suggestions. I have some decisions to make.
