Tester Says Wiring Correct, Multimeter Says Otherwise
Old 05-27-23, 06:05 PM
D
I have an outlet that isn’t working. I pulled it out. I have two black, two white wires and a ground. Plugged in my tester and the two lights indicating correct lit up. I hit it with a multimeter and nothing . . . . so something was powering to get the tester to light up. When I use my probes to black and ground, I get 120v. This place has always baffled me with the electrical. What the heck is going on here? How do I remedy? Both black wires are hot.
Top Answer
05-28-23, 04:34 AM
joed
joed is offline
Received 499 Upvotes on 410 Posts
You have an open neutral somewhere. Most common cause of this is back stab push in connections. Check other devices on the circuit and move any back stabs to the screws.
Old 05-27-23, 06:10 PM
Tolyn Ironhand's Avatar
Received 778 Upvotes on 658 Posts
What do you get when you put one probe on black and the other on white? Measure directly from the wires, not the device.
Old 05-27-23, 06:13 PM
What does your tester say when you plug something like a lamp into the second receptacle and turn it on?
Old 05-27-23, 06:26 PM
D
I get nothing on the multimeter when black to white.
Old 05-27-23, 06:30 PM
D
@joed when I do that I get “hot and ground reversed” lit up.
Old 05-27-23, 11:33 PM
d_s_k's Avatar
Received 19 Upvotes on 17 Posts
So:
black - ground = 120V
black - white = 0V
white - ground = ?? V
Even when a multimeter may have some % +/- What is the exact readings?
What kind of a meter did you use?
What happens if you put a load between black and ground?
What happens if you put a load between white and ground?
Old 05-28-23, 04:34 AM
AFJES, CasualJoe, sdodder voted this post useful.
Old 05-29-23, 12:43 AM
A
Received 147 Upvotes on 123 Posts
I agree is joed. This is where you should start.
Old 05-29-23, 10:38 PM
G
Received 11 Upvotes on 10 Posts
I suggest checking the wires in this outlet, as well as the ones upstream.
Neutrals that are pigtailed together may also fail.
It's odd you have only one outlet that fail; the downstream outlets (or lights) should also fail.
BTW you cannot rely on outlet tester to tell you what's wrong because sometimes there are multiple possible reasons for one symptom and the tester only tells you the most likely one.
