Is this LED Type A/B bulb wired correctly?
Old 09-27-23, 11:05 AM
G
Is this GE LEDAB15T8G4840-LT10 Type A/B LEB bulb wired correctly for Type B mode; i.e., direct to AC?
Thanks!
gfr92y
Old 09-27-23, 04:38 PM
Tolyn Ironhand's Avatar
Received 814 Upvotes on 685 Posts
Do you have a wiring diagram that came with the lamps?
gfr92y voted this post useful.
Old 09-27-23, 05:33 PM
Received 3,750 Upvotes on 3,362 Posts
Wow.... GE has entered the pits. Little to no technical help.
A type "A" replacement uses an existing ballast.
A type "B" replacement uses no ballast and sockets get rewired.
Your diagram does match the GE type B diagram
I like the addition of a fuse. Anywhere from 1-5A is good.
As mentioned....wiring should be confirmed to match packaging.
Old 09-27-23, 06:53 PM
Kooter's Avatar
Received 88 Upvotes on 81 Posts
I highly recommend these for T8 retrofit to LED:
https://www.superbrightleds.com/led-...-Natural~4000K
I highly recommend these for T12 retrofit to LED:
https://www.superbrightleds.com/indu...ulb_type=85030
Old 09-28-23, 05:22 AM
G
Everyone,
I feel like such an idiot!
For two weeks now, I have been looking at the back of the box of bulbs wondering why they only offered Type A wiring instructions. I really thought I did a good job of looking for the Type B instructions.
At one of the poster's encouragement, I went back and looked at the box and once again wondered why they only had the Type A instructions. Then I glanced at the other end of the box and noticed that upside down where the Type B instructions. Thank you so much for asking if there were instructions with the bulbs.
Thanks, again!
gfr92y
Old 09-28-23, 05:27 PM
Good job. (and now you know)
