I need help with just purchased tanning bed
Old 09-30-23, 05:36 PM
H
I just bought a 1984 suntana sunsystem model sb3 serial number c300 made by sun industries llc from a lady on Facebook for $300 got it home an all hooked up an it wont turn on, I think it's a wiring issue but I can't find any dias and the manual to take it apart an see what's what... please help it all can't be a loss
Old 09-30-23, 05:50 PM
Kooter's Avatar
Received 88 Upvotes on 81 Posts
24 amps is a pretty hefty load for a 120 volts appliance - if you can call a tanning bed an appliance!
Are you setup to handle that load with the correct gauge circuit wiring and overcurrent protection and NEMA receptacle and corded plug?
Old 09-30-23, 06:12 PM
Received 3,749 Upvotes on 3,362 Posts
Welcome to the forums.
There never has been a wealth of technical help available online for tanning products.
Could try here.... tanning bed repair manuals.
For us to help you.... we'll need pictures of the area where the wiring connects.
How to insert pictures.
How many tubes ?
How many ballasts ?
Old 09-30-23, 07:16 PM
Kooter's Avatar
The SunSystem Model SB-3 has 16 Bulbs
I think this is the one!
Check out that makeshift wiring!
Old 10-01-23, 10:25 AM
H
This is what I got
Old 10-01-23, 10:26 AM
H
Reply to 16 bulbs
Mine has 24 an it's a 110 not a 220
Old 10-01-23, 05:54 PM
You can use that metal clad cable for testing with the plug on it but it needs to be replaced.
Technically it may use more power than you can get from a wall socket.
Either it will eventually need it's own direct circuit (30amp) or a very good power cord.
You need to remount that box with screws.
I labeled blower in first picture. According to the labeling of those three plugs... blower should be connected to the right plug except I see a black cable (?) and a device (?) on the cover in place of the blower. Can you ID what that device is with the ? ?
I labeled the 4th picture with timer and a circle around the plug. It looks to be broken.
The bed won't operate without the timer connected.
How do you know the bed operates on 120v ?
Is there some tag.
A bed of that many tubes usually runs on 240v.
CasualJoe voted this post useful.
Old 10-01-23, 06:03 PM
Tolyn Ironhand's Avatar
Received 812 Upvotes on 684 Posts
Yeah, that is going to need a separate dedicated 30 amp circuit if the unit is running all lamps and blowers. It will have to be gone through to check all the wiring is good and check each ballast and UV lamps to see if they are all working. Was the unit tested/working before purchase?
CircuitBreaker voted this post useful.
Old 10-01-23, 06:10 PM
Kooter's Avatar
Is there some tag.
Pete - The OP said it's a Model SB-3.
Here's the tag for a SB-3 - says 120 volt! 24 amp!
Old 10-01-23, 06:17 PM
OP also said it was 16.... not 12 tubes.
I would like to wait to hear from OP BEFORE any other posts.
