lights and switches
Old 12-05-23, 05:14 AM
C
lights and switches
i have two lights and tow switches on one circuit. can i change them them each one one switch on one light?
Light Switches Sharing A Neutral Wire
Old 12-05-23, 06:40 AM
B
Received 286 Upvotes on 254 Posts
Connect wires as shown in your diagram of post 1 and one switch will only control one light.
A
Received 272 Upvotes on 248 Posts
The diagram correctly shows what you want to end up with.
What do you have now to start with? For example are the two switches you have now in different locations?
cduckett voted this post useful.
Old 12-05-23, 10:03 AM
Z
Received 120 Upvotes on 111 Posts
Sounds like current setup is two 3-way switches, each turning ON/OFF both lights at the same time. So, after conversion the final connections to the switches (reusing the 3-ways) will look a little different.
Old 12-06-23, 04:11 AM
A
Received 159 Upvotes on 132 Posts
I agree with zoesdad
OP states:
​​​​​​​i have two lights and tow switches on one circuit.
I am thinking the OP presently has a 3 way setup but referring to the 3 way setup as being "on one circuit".
Old 12-06-23, 04:26 AM
C
t,he two switches are on different walls and so are the lights, one in the flyer and one in the hallway. i dont know what wires i should change
Old 12-06-23, 04:27 AM
C
do i change the wires on the switch or the lights?
Old 12-06-23, 06:14 AM
A
Received 110 Upvotes on 95 Posts
probably need more information on what you want to do and what you have now same circuit to me would be they was on the same circuit breaker but is it a 3 way now can you turn on and off both lights with either switch?
will likely need to pull the switches out and take a picture of how there wired now and same with the light fixtures that will help the most for people to give you advice on how to switch it over to one switch to one light.
