GE half-size circuit breakers
Old 02-25-24, 08:59 PM
L
Any problems with using GE half-sized breaker switch for 50 amp service? I have only one empty slot in my panel box. This will be for electric vehicle feed.
Old 02-25-24, 09:03 PM
Received 3,982 Upvotes on 3,574 Posts
Welcome to the forums.
You need 240v @ 50 amps for the charger... correct ?
You can only get 120v with a half size breaker.
You need to use a breaker that connects on to the bus with two stabs.
Old 02-25-24, 09:09 PM
L
you are absolutely correct. I was thinking that there are half-sized breakers for 240 amp service. I'll look again...
Old 02-25-24, 09:18 PM
L
I guess that I thought this was for 220/240 VAC. I'm wrong?? In any event, Is there a way to provide 220VAC 50 AMP service with only half-sized opening without replacing my panel box?
Old 02-25-24, 09:54 PM
This is a tandem quad. It uses 2 large slots and gives you 4 breakers.
This is just an example....quad.
We'd need your breaker type or picture of the label on the door.
Old 02-26-24, 03:42 PM
Tolyn Ironhand's Avatar
Received 878 Upvotes on 741 Posts
You could use a two pole 50 amp breaker like that if:
1) Your GE panel accepts THQP breakers
2) You have a 1" space in the panel open
3) That 1" space allows the breaker to plug into 2 buses (Note: If you have other thin GE breakers you might be able to just move some breakers around to get the breaker in the right spot.)
CasualJoe voted this post useful.
Old 02-27-24, 07:35 PM
L
Thanks Pete, the only label I find is behind the cover. As you can see it's pretty much useless.
I'm happy to supply other informatioin if helpful.
Also - just read your reply Tolyn. I'll do some research and respond.
Old 02-27-24, 09:39 PM
I'm trying to read the model number. I know it's a GE TM20xxxxxxxxx.
200A either 20 space or 20/40 space.
There is only 120v (B bus) available in the bottom location.
You would need to replace the bottom breaker with a 1/2 space breaker.
You'd need a single space 2P breaker would go below that.
That would leave a 1/2 blank or a 1/2 breaker for spare.
Old 02-28-24, 06:43 PM
I can't tell for sure, but that picture of the bus doesn't look like it has the right bus bar to take the thin breakers. Can you take a closer picture?
Old 03-04-24, 08:49 PM
I used pictures of actual panels on ebay. Pretty sure that's the 1/2 breaker clip.
If you look closely at the sticker it looks like all spaces are 1/2's which would mean 20/40 panel.
