Help With Selecting Disconnect Box
Old 04-10-24, 12:13 PM
I have a boat lift. The wiring went to a junction box with a 2 pole light switch to cut off power with no protection besides the breaker in the house. The voltage is 240 (2 blacks and a single white neutral).
I want to replace it with more protection. I am thinking of using the attached 3 pole box with fuses inside. It says it is rated for outdoor use. Does this make sense? The breaker inside is 30A, so I would use 30A fuses in the new box also. If there are better options please let me know and thank you.
Old 04-10-24, 12:32 PM
L
Received 38 Upvotes on 32 Posts
Couple things:
1) It's not necessary to disconnect the neutral
2) The neutral must NOT be fused
slynch401k voted this post useful.
Old 04-10-24, 01:45 PM
Thanks Luke, so are you saying I can us a 2 pole box instead? Wire nut the neutrals together and then each black leg on each pole?
Old 04-10-24, 01:50 PM
L
Yes.
Old 04-11-24, 08:23 PM
Received 4,046 Upvotes on 3,630 Posts
That's interesting. Are you sure that's a neutral ?
A 240v hoist should be two hot wires and a ground....,. not neutral.
Old 04-12-24, 06:50 AM
Pete;
confused with the single neutral on the GFIC. Can you look at my diagram and advise? Thank you.
Old 04-12-24, 06:56 AM
P
Received 274 Upvotes on 231 Posts
Is the boat lift circuit GFCI protected? If not, that's more important to add vs. a second layer of overcurrent protection. The GFCI protection should most likely be back at the house.
Old 04-12-24, 08:42 AM
Before it was wired as a 2 pole on/off switch to a GFIC. When the GFIC tripped the lift would not work. I don't think it would actually save a spike to the house. I can put a 30amp dual gfi breaker in my house. I am weighing options before reassembling. Want to protect the control box though. Thanks for the reply.
Old 04-12-24, 01:40 PM
Does the control box require a neutral ?
That means you would have two hots, a white neutral and a green ground.
Four wires from house to lift.
Most hoists/lifts do not require a neutral.
If I had a boat lift... the GFI protection would not be in the house.
Who wants to walk back to the house every time there is a trip.
You can put a GFI breaker at the lift that connects to both the hots and neutral.
Your diagram shows a neutral to the control board but you would not be using a GFI receptacle.
Old 04-12-24, 02:06 PM
The control box does have a neutral. There are 4 wires from house to disconnect. After reviewing the pics that I took, and researching the net, I believe this is how it was wired. Does this make sense and what you would do?
Old 04-12-24, 02:23 PM
You are showing a GFI receptacle protecting the control board only.
Does the motor require protection too ?
Can you leave a link to the lift system .
Old 04-12-24, 02:56 PM
Thank you. I see what you are saying. I thought the fuses in the disconnect would solve that. Here is a pic from the bottom of the motor.
