Single Circuit Transfer Switch Wiring
Old 05-28-24, 06:02 PM
I want to install a transfer switch so I can hook a generator up to a mini-split ac unit. I would like to use the Reliance CSR-302. I want to confirm the wiring. The existing disconnect wiring is shown below along with the the CSR-302 diagram.
I believe that I wire the incoming red and black wires from.my main panel to the two red wires in the transfer switch, the two black wires coming from the mini-split to the two blacks in the switch and then the white to the white. Correct?
Old 05-28-24, 06:27 PM
Tolyn Ironhand's Avatar
Received 900 Upvotes on 761 Posts
The white in the disconnect is not being used as a neutral, it is being used as a ground. I suggest you confirm this and perhaps figure out where the bare ground in the NM cable is.
Old 05-29-24, 04:18 AM
This is an older home (1991). There isn't a bare ground in the NM cable coming from the panel. This is the second time I've found this, the other was to an abandoned 240v outlet for an outdoor electric stove.
Old 05-29-24, 04:45 AM
P
Received 2,271 Upvotes on 2,023 Posts
The problem is your work has to be brought up to the current code because you are installing a new device. So, you need two hots, one neutral and one ground.
Old 05-29-24, 04:58 AM
Received 521 Upvotes on 426 Posts
That is not old enough to be missing the ground. Ground would have been required at that time.
CircuitBreaker voted this post useful.
Old 05-29-24, 01:43 PM
My equipment is only looking for two hots and a ground. If I installed a ground, what happens to the neutral?
Old 05-29-24, 02:59 PM
The neutral would not be used. However, does your transfer switch require a neutral? Is it an automatic transfer switch or a manual?
Old 05-29-24, 03:53 PM
It is a manual transfer switch and has a neutral (wiring diagram above). I don't know if having one means it requires one. If I connected the neutral from the panel to the neutral in the switch and it "ends" there, that would work, correct?
Old 05-30-24, 04:39 AM
A
Received 288 Upvotes on 263 Posts
A manual transfer switch serving a 240 volt only device would not need a neutral. Perfectly okay to connect the neutral from the feed to the neutral terminal (if any) on the transfer switch and leave it unused otherwise.
