How do I connect a 4-wire fixture?
Old 08-19-01, 03:30 PM
Question
I just bought a light fixture with 4 wires - 2 black & 2 white. In the ceiling there is 1 black & 1 white. Which wire(s) do I connect?
I tried twisting the 2 blacks (from the fixture) together to the black in the ceiling (ditto white side), but no luck. I decided then to stop experimenting.
FYI, neither ceiling wire is hot when the wall switch is off; the ceiling wires are only live when the wall switch is on.
Thanks.
Old 08-19-01, 03:52 PM
Rookie,
Your first experiment was correct. It should have worked.
You might help us by defining "no luck."
Here are some possible problems:
  • You didn't make the connections very well. Did you use the correct size wire nuts and did you make the connections correctly?
  • Does the fixture possibly have a toggle switch on it that you didn't toggle?
  • Did you turn the breaker back on and the wall switch too?
  • Perhaps you have a bad fixture or a bad bulb.
Post back.
Old 08-19-01, 07:47 PM
Question
By "no luck" I mean the bulbs did not light up when I flipped the wall switch after joining 2 blacks to black & 2 whites to white. Also:
- the fixture itself has no switch
- the breaker was ON in addition to the wall switch
- I tried different bulbs in different sockets (the fixture takes 4 bulbs)
Does it matter that there is no power in the ceiling wires when the wall switch is OFF? Isn't there a scenario where I'd join:
- black+black+white to ceiling's black
- white to ceiling's white
Would I do the latter if the ceiling was receiving power even when the wall switch is OFF?
Thanks again.
Old 08-19-01, 08:04 PM
No, this is correct whenever you only have one black and one white wire coming out of the box.
Isn't there a scenario where I'd join: black+black+white to ceiling's black & white to ceiling's white
Absolutely not!
Absolutely not!
Again, you wired it correctly the first time. My best guess now is that you have a bad fixture. Where did you get it?
