HELP!!..Need to wire up my SPA...
Old 08-20-01, 09:03 AM
masterjoe
Cool
I recently got an used 5-man spa on my deck. I have to run 220V 30Amp wiring all the way from my
backyard to the breaker panel in the garage. I'll appreciate any hints or tips on how to run it and through
where to run it and how to hook it up to the Bus...I have 2 open slots on the panel.
Should I run it along the side of the house in a conduit and run it inside?? What's the proper way to wire it
up??
Thanks in advance...
Old 08-20-01, 05:46 PM
Wgoodrich
Try the following link. This should be close to what you want to do. I question your 30 amps. You should look at the owner's manual. I strongly suspect this hot tub will require a 50 amp branch circuit. Try the following link, then read you name plate amp rating for your hot tub branch circuit, then come back in with you further questions. The above may give you a good start and a source for more questions.
http://homewiring.tripod.com/hottub.html
Good Luck
Wg
