Doorbell
Old 10-04-01, 10:17 AM
Todd B
Smile
I have mounted the doorbell transformer on the panel.
Should I put it on it's own 15 amp breaker?
- or -
I have one outlet that I installed next to my panel for the cable TV amp to plug into (Nothing else is on this circuit). This is on a 20 Amp breaker. Can I add the doorbell to this breaker also? (That would mean two wires attached to one breaker, I think this is a violation, correct?) Or should I pigtail a wire from the 20 amp breaker and wirenut the doorbel and outlet together inside the panel?
Todd.
Old 10-04-01, 10:24 AM
There's no need for the doorbell to be on a separate circuit. Rounded off, the doorbell uses zero amps.
Many breakers are designed to accept up to two wires. Or you could do the pigtail trick too.
