dimmer switch
We recently replaced a standard light switch with a dimmer switch. However, unless the dimmer is on full light, the light fixture buzzes. Is this something that can be corrected?
This is a common problem. The general suggestion is to try a different brand of light bulbs. Some brands seem to have this problem more than others. You might try a better brand, if you can figure out how to determine that (I can't).
