Please It Is An Easy Question
Old 12-03-01, 12:31 PM
Guest
Exclamation Please It Is An Easy Question
HOW DO YOU REWIRE A TELPHONE WIRE IN SIDE ?
GREEN WITH GREEN
RED WITH RED
BLACK WITH BLACK
AND YELLOW WITH YELLOW am i correct ?
if that dont work and there is still no dial tone what could the problem be i know it is not the phone company cause i have already did the test to make sure
Old 12-03-01, 01:27 PM
Wgoodrich
First things first did you lose your phones without touching your wires. If so put everything back as it was then unplug all phones, answering machines, faxes etc. in the home. Wait 5 minutes or so and plug one phone in and see if you get your phones back. If you have a phone or machine connected to the phone lines and if is off the hook or is malfunctioning then you will loose your phones until the problem is corrected and the phone company resets the phones once they were cleared. The phone company will do this automatically in about 10 minutes once you have your phones all unplugged.
If you are adding a phone then you probably wouldn't have lost all the other phones. in your home.
By the way yes the colors all match up with like colors.
Let us know if this hit your problem. Just gave an experienced guess that you lost your phones without having touched your wires originally.
Wg
