replacing 3way fan switch
how do you replace a 3speed fan switch. i took it apart and i tried to put it together but it does not work i know ther is l,1,2,3. on the switch which is the right way to deternine how to hook up the wires?
If you already know that l is line and the 1 2 3 is the speeds of that fan then you must be having trouble finding high is low etc. If this is your problem then you need to hit the speed that truly is high and move that wire of the 123 to the hight speed switch screw. Follow the same process of elimination to get the rest of the speeds matching where they are supposed to be.
If you are having a different problem then you need to explain what you mean by "not working right"
Wg
Wg
