Would a lower watt microwave help
Old 01-22-02, 07:13 PM
Guest
Question Would a lower watt microwave help
I have a 1200 watt microwave in a bedroom plugged into a regular curcuit that I assume includes the overhead ceiling light fixture and an outlet that has a desklamp and a very small refrigerator plugged into it. The microwave often makes the curcuit break, even if the refrigerator is not running at the time the microwave is in use. If I replace the 1200 watt microwave with one of 700 watts or 500 watts do you think this would this solve the problem?
Old 01-23-02, 06:33 AM
HandyRon's Avatar
It might. Do you have access to an amp meter? You can check the load.
