Adding 20A tandem breaker to QO panel
Old 01-27-02, 04:53 PM
hotarc
I have a Square D QO Load Center with 16 breaker positions. Slots 1 & 3 are occupied by a 30 AMP double for the dryer circuit; 2 & 4 is a 60 AMP double pole marked MAIN on the circuit list; 5 & 7 are empty, 6 & 8 is 40 AMP double pole Range circuit. There are stickers that were applied to the metal cover inbetween the left and right banks of breakers reading: MAIN DISCONNECT. These stickers are applied next to each slot 1-8. Below these there are (7) 15 AMP branch circuits on the right (3 tandems and 1 single), and (5) 20 AMP branch circuits on the left (2 tandems and 1 single). My questions are:
(1) Can I add a 20 AMP tandem breaker (two 20 amp circuits) to slot 9 on the left side without overloading the panel?
(2) Are the range and dryer circuits really main disconnects or were those labels incorrectly applied?
(3) Is there any way I can calculate how many amps my service is? The map on the door says the panel is rated up to 150 amps, so I assume it's not any more than that.
Any help is greatly appreciated.
Old 01-27-02, 06:30 PM
Jxofaltrds
Hotarc you should be OK. What overloads the service is everything on at the same time.
Why not use 5 and 7?
Old 01-27-02, 06:40 PM
hotarc
I wanted to leave them open in case I install air conditioning in the future. Also, I'm unclear about the main disconnect and if 5 & 7 are part of it in some way.
Old 01-27-02, 06:52 PM
Jxofaltrds
Hotarc I am going to bow out of this one. My "gut" says that I am going to steer you wrong . Too much on my mind.
Old 01-28-02, 09:06 AM
T
Sounds like you may have a split-bus panel. Where are the wires connected in the service panel from the electrical utility meter? You didn't mention any loads for space heating and a water heater. Are they natural gas?
Old 01-28-02, 09:27 AM
hotarc
If my understanding of a split bus is correct, then I have one. I'm assuming a split bus mean that two adjacent slots, such as 1 and 3 are on different phases. Moreover, 1 and 2 would be on the same phase. There is a red conductor connected to one side of the panel and a black connected to the other. My water heater and furnace are both natural gas and the furnace blower is on a dedicated 15 A breaker.
Old 01-28-02, 10:04 AM
T
How much load are you adding to the panel? What will the new 20 amp circuit supply?
If this is in fact a split-bus the answer is yes. Circuit breakers 1-8 are the main disconnects. The 60 amp circuit breaker turns off circuit breakers 9-16.
You need to find out the wire size (gauge) of the hot (black & red) service-entrance conductors. This will designate their ampacity. Are the black and red service-entrance conductors connected to the main lugs in the service panel?
Old 01-28-02, 11:41 AM
joelp
You need to be careful when using a tandem breaker. Do not use 12/3 as you will be sharing the neutral and could overload it.
Old 01-28-02, 12:55 PM
hotarc
One 20A circuit will first connect to a 120V smoke detector in the basement, next a GFCI protected duplex receptacle and from that I was planning to connect two more duplex receptacles, all located in an attached garage.
These three receptacles will be primarily for a circular saw, miter box, electric drill, and will be used rather infrequently and almost never simultaneously.
After the three convenience receptacles I would like to install two or possibly three outdoor incandescent ighting outlets with 75-100W lamps.
The other 20A circuit will power the basement and supply 4 shoplights, each with two 4' 40W tubes, and 4 duplex receptacles which will power the miter box and circular saw, when I'm not using them in the garage, and occasionally a small tv or radio. The lights will normally not all be used simultaneously.
I will have to remove the panel cover to determine the service entrance conductor size. It is an underground feed and there is not enough exposed cable to see the markings.
I will be running two separate 12/2 NM cables. I don't want to share the neutral. Too many potential drawbacks.
