Wierd Electrical Problem
Ok, all of a sudden my bathroom lights/fan doesn't work. I get out my tester (It's just a light that lights up when there is juice) and test the connection in the switch. I got juce there. I take apart the light fixture and I get juice there. I put it back together and test the light sockets, I get juice there. I test the light bulbs somewhere else and they work. I put the bulbs back in the socket and they don't work. I test the sockets again, I get juice. I pull out the prongs in the fixture to make sure there is contact. Still don't work.
What do I do now?
Thanks
What do I do now?
Thanks
Received 0 Votes
Are you checking the voltage between the hot wire and the white wire at the fixture and switch? You might try looking for loose/bad neutral connections in the switch box and fan/light fixture.
I didn't check the actual voltage as far as how much. I did test it with my light tester thingy. I connected 1 to the black wire and the other to the white wire and it lit up telling me that their was juice, just don't know how much.
I did this at the switch, light fixture, and the light socket. All have juice.
No, the GFCI circut is wired to the outlet on other wall. It still works. The switches are wired to a different breaker. Not sure what it is called but it has 2 little switches on it. I've turned them off and on to see if that helped but it didn't.
If your tests were done correctly, then the only way to get a reading on the tester but no light from the bulb is that the voltage is too low when under load. This points to a poor connection somewhere. The only suggestion is to look for it. Move all connections using the push-in backstab connectors to the adjacent screws, and make sure all wirenuts are tight and that you can't pull the wires from them (pull on the wires one at a time).
When you say "the circuit" do you mean the circuit breaker? Breakers do go bad, but I've never heard of one failing in a way that could cause your symptoms.
If your hunt for a bad connection fails, then I suggest you reevaluate your testing procedure. It might be flawed in some way that we cannot identify remotely (even though everything you've said sounds good to me). I assume you're using one of those $2 circuit testers with a neon light -- is this true?
You got it, 2 bucks.
I did mean the circut breaker.
I have a friend that can lone me his voltage tester, but that won't be till tomorrow.
It's wierd how it went out. I was just in the bathroom a few mins before then when I got back in and turn on the lights, nothing. I don't get it. I even replaced the switches.
A voltmeter will not allow you to detect low voltage under load, since you'll be using the voltmeter without a load. So your friend's voltmeter may not help in this situation, but it can't hurt any either.
