4-way and 3-way switches
I put some lights in my basement hallway. I started with 2 wire cable into a fixture, switch looped to a 3-way switch. From there I ran 3 wire cable to a 4-way switch, and more 3 wire cable to another 3-way switch. Works great...my problem is I want a second fixture and cannot figure out how to connect in. Do I connect into the first 3-way switch, the last, the first fixture or what? I also need to know if I have to use 2 wire, 3 wire, or even 4 wire cable. Thanks for any help and sorry if I confused anyone.
Received 0 Votes
Simple. Run a 2-wire cable from the first fixture to the second. At the first fixture, connect the new cable to exactly the same wires that the first fixture are connected to.
Previous Thread
Next Thread
