Junction within a circuit
Basic question. Can I simply cut a junction in an existing circuit and tee off to a new device? In other words, in the JB I'll have three wires 14/2 or 14/2 with three blacks (attcahed) three whites (attached) and three grounds (attached). Thanks in advance.
Peter
Peter
Yes, that would be a simple standard for a branch circuit. You will need to ensure of course that whatever you ultimately attach to the circuit does not overload the existing wiring/breaker.
Received 0 Votes
You also need to make sure of the following:
(1) Assuming you are cutting into an existing cable, you need to have enough slack in the cable to actually make the splice inside the junction box. You'll need at least a foot of slack to make a proper splice.
(2) The junction box must be accessable (not buried under drywall, for example).
