converting 220 to 110 voltes
Old 03-18-02, 12:33 AM
hamza15
Question converting 220 to 110 voltes
wanting to change 220 outlet to 110 outlet
what needs to be done? please help!!!!!
Old 03-18-02, 05:16 AM
D
Are you taking about wanting to use the same wire and box? Do you want to install a single pole breaker. Use either the black or red wire to one side of the receptable and white to the other. Inside your panel you may want to change the breaker to a 15 or 20 amp depending what else is in the new circuit you set up. The black or red wire you did not use will be tied of or eliminated.
