Lots of new wiring
Old 03-25-02, 07:36 AM
DawnKristen27
Unhappy Lots of new wiring
I have a couple of questions??
How do I add a light over my kitchen sink. There is nothing there right now. Can I run 14-2 from the panel to the switch box and then to where I want the light
I also want to add a switch to my bedroom to control a plug. I ran a piece of 14-2 to the switch from the panel and then a piece of 14-3 to the plug I want to control but I am not sure how to connect it all??
Old 03-25-02, 09:08 AM
HandyRon's Avatar
1st question: Yes
2nd question: A picture is better than typing it out. Check out this web site.
http://homewiring.tripod.com/switcho...lethalfsw.html
Old 03-25-02, 09:16 AM
P
It wasn't necessary to run a cable from the panel for a switch-controlled general-purpose recepacle in the bed-room unless possibly this is a "specific purpose" receptacle.-----At the switch wire-nut the 2 White wires -----wire-nut together the 2 Black wires and an 8" Black lead----connect the Black lead and the Red of the 3-wire to the 2 switch terminals.------ Twist off the link between the 2 copper terminals on the receptacle-----connect the White of the 3-wire to a silver terminal on the receptacle and the Red and Black to the 2 isolated copper terminals.--I haven't mentioned Grounding connections so ask if you'r not certain on this point.-----We'll need a brief description of the kitchen-lath and plaster or sheetrock?--cabinet over the sink?---what type fixture, etc. Please reply-thanks. p.s.,you don't need a cable from the panel.
Old 03-25-02, 10:49 AM
DawnKristen27
For over the kitchen sink just a normal kitchen light, a flourescent light maybe.
Also where do I get power from if I don't run from the panel for the light. Also, in the room where I want the swithced plug there are already plugs in the room, can I pull power from one of those?
I am kind of confused.
