Low voltage outdoor lighting
My outdoor low voltage lights have stopped working. The electrical outlet is working. Any ideas where to start to diagnos the problem?
outdoor lighting
crazycelt59
It seems you tring to power up your landscape lights. I take it you have connected a 12 volt transformer onto your working 115 volt outlet. Now test the output of your transformer to see what voltage you are getting. Then check your splices that connect the lights onto the wires from the transformer.
Good luck.
Good luck.
