NM Clamp Connector Capacity
Old 04-06-02, 03:26 PM
Can I put two NM 6-3 w/g through a single 1.25" NM clamp connector?
Old 04-06-02, 04:32 PM
Wgoodrich
The romex connector would not be listed for use as you discribe. You might want to ask for a ruling from your AHJ but I suspect he will say the same thing
Hope this helps
Wg
Old 04-08-02, 07:44 PM
OK, I suspected that. How do you determine the appropriate size clamp connector for a given NM cable? I looked on the packaging and on the Halex web site but did not see a listing (I expected lists similar to the extensive ones found on wirenut packages). What size would I need for my NM #6-3 w/g?
Old 04-08-02, 08:52 PM
Wgoodrich
Romex connectors are usually sized equal to the widest measurement of the cable being secured.
Good Luck
Wg
