Power factor formula
Hey,
Need to try and find a formula used with electrical motors.I know the power formula,IxE=Pwhich is watts and I know ohm's law but this one formula has to do with a percentage.The question goes something like this.If you have a single phase motor and it's pulling 1 amp the power factor is(for example) 86%.I would appreciate any and all help,I'm actually trying to help a friend out who like me has alot of books but maybe not the right one.We want to know how they end up with the % value.
Thanks in advance
Thanks in advance
Power factor is related to the voltage leading or lagging the current waveform. Once you determine the angular difference in the waveform (on an ossiliscope), you take the cos(angle).
The applicable formulae are power factor pf = cos ( angle ),
I = Current, V=Voltage
Apparent Power ( P ) = I · V (this is in units of VA)
True Power = P · pf (this is in units of watts)
A Brewer, Here is one more example I dug up out of one of my old school books.
Cosine=VR/V From the voltage triangle
Cosine=R/Z From the impedance triangle
Cosine=W/VA From the power triangle
Example:
Power factor= W/VA = 500/625 = 0.8 or 80% lag
Power factor= R/Z = 20/25 = 0.8 lag
Power factor= VR/V = 100/125 = 0.8
Of the three forms given for the power factor, the most commonly used is:
Power factor= W/VA
W = V x A x cosine
or
W = V x I x cosine
Where cosine = power factor
From: Alternating Current Fundamentals(Third Edition)
By: John R. Duff/Stephen L. Herman
Published by: Delmar Books
Example:
Power factor= W/VA
W = V x A x cosine
or
W = V x I x cosine
I also meant to mention, refering to your % thoughts, that power factor is sometimes refered to as either a decimal or %. For example, a pure resistive load will result in a power factor of 1.0 or 100%.
