more question on rough in
Old 05-15-02, 04:58 PM
B
on the romex clamp in top of circuit breaker box. You told me to read the bag on how many wires per clamp. Not There! Anybody have a code number on this.
How much romex plastic coating in the box pass the clamp ?
In outside meter box, Can I use those strap tie to hold my 3/0 cu wire together, out of way.
UPDATE. Got the conduit install for the feeder line, it wasn't easy. Glad that part over.
Old 05-15-02, 05:12 PM
hope this helps
You wont find a code referance for how many to put in a connector, because there are so many different kinds of connectors. Just use the method I gave you last time.
As far as how much insulation to leave inside the box, 1/4 inch is what the code asks for. yes you can use tie wraps to hold your wires back in the meter, as long as they are made entirely of nylon or plastic.
Old 05-15-02, 06:36 PM
B
What about bonding of the boxes,( main, circuit breaker, subpanel)
Old 05-15-02, 06:42 PM
hope this helps
What do you have running beween the panel and the meter? As far as a raceway.
Old 05-15-02, 07:22 PM
B
2 inch plastic conduit.
There was a green screw in each box that said " If bonding is required install green screw in neutral bus bar attaching to box"
Old 05-15-02, 07:48 PM
Ok , the green screw should be installed in the meter already, and if i remember correctly your panel is located remotely from your main disconnect. The box that has your main disconnect in it, install the green screw, the box that is located remote do not.
