installing a light to ceiling fan
Old 05-22-02, 02:52 PM
desireeo
i am trying to install a light to my fans. i have attached the blue in the ceiling to the black on the light fixture. i also attached white to white. the light still does not work. both the blue and the white from the fan are labeled "for light". all of the wires are secured with wire connectors. I will appreciate any help. Thanks!
Old 05-22-02, 06:24 PM
Wgoodrich
Drop your cone to your fan at the ceiling and see if the blue wire is connected to anything. If it is not then connect it to the same wire the black wire of the fan is connected to and you light will work with the fan then controlled by the switches on the fan.
Hope this hits what you have just a hit in the dark
Wg
Old 05-22-02, 07:53 PM
desireeo
Thumbs up thanks
thank you so much. i will try it tomorrow morning. after thinking about it for awhile i realized that i needed to check to see if there was any electricity. so i used my little sensor and that was the problem. thank you so much for the confirmation!
