irrigation pump
Old 05-23-02, 09:16 AM
darwin
irrigation pump
I plan on using a 1 hp irrigation pump and a generator to draw water from a ditch to water my lawn. The pump can be wired 120 or 240 and the generator has both outlets. Which option is best? Thanks Darwin
Old 05-23-02, 12:05 PM
Received 1 Vote on 1 Post
If you have 240 volts available where your pump is, the higher voltage will reduce voltage drop in the wires. This is especially important if the electricity has to go a long ways to get to your pump.
If you currently have 120 and getting 240 would be a pain, then go with the 120.
