bad wires
Old 05-23-02, 02:19 PM
bad wires
I have 2 single pole switches that control 2 different lights in my bathroom. The source of power into the switch box is from 14/2 wire with ground. I also have 14/3 wire with ground coming out of the box and going to a 3 way switch.The problem I have is when I shut the switch that controls the light over the sink , I still have power in the line when tested . What I would like to know is how to hook up this system the right way. I took all the wires apart and can't seem to figure it out. Thank you Joe 4h
Old 05-23-02, 07:11 PM
Wgoodrich
IF you have power in the first switch and switch leg to the light fixture coming from the second switch of that certain three way switch system take a look at the fllowing link [3 way switch].
http://homewiring.tripod.com/switcho.../3waysame.html
If you have power and switch leg in the first switch and a three wire cable going to the second swich with no other cables involved with that second switch in its box then take a look at the following link [3 way switch]
http://homewiring.tripod.com/switcho.../3wayboth.html
Hope this helps
Wg
