220V Electric Motor Hook-up
Old 05-28-02, 07:13 PM
glueckspilz
Question 220V Electric Motor Hook-up
Looking for proper wiring schematic to connect 220V to motor for a table saw.... any clues?
Old 05-28-02, 09:39 PM
FREDDYG_001
glueckspliz, Post back with all the imformation off the nameplate of this motor. Either myself or one of the other guy's can research the imformation for you.
Fred
Old 05-29-02, 06:45 AM
Received 1 Vote on 1 Post
The high-level view is to install a new double-pole breaker, run a new cable (probably NM x/2) from the panel to where the saw is, and install a 240-volt receptacle there. The wiring is trivial -- connect black and white to the breaker at one end, and to the two slanted slots at the other end, and connect the grounding wire at both ends. To provide more specific help, please reply to Fred's request.
