Dishwasher Door
Old 05-30-02, 08:17 AM
khanif
Question Dishwasher Door
I have a GE 10 years old dishwasher. It's door spring is broken.
I want to know how to put a new one and where(most important).
Thanks in advance.
Old 05-30-02, 08:22 AM
Libor
Check out the "Appliance--Electric" forum. They're better equipped to answer this type of question, as they deal with it all the time. You may get a good answer from folks here, but there's a better chance you'll get something from that other forum. Good luck.
Old 05-30-02, 11:57 AM
Wgoodrich
YOu should be able to remove the bottom face plate of hte dishwasher and see the springs on each side of the door. You should be able to unhook the broken spring and use a pair of pliers and a vise to bend the ends of hte sping to make two new hooks on the two pieces of broken spring. Then you should be able to reinstall the tow springs hooked together using hte newly made hook ends and rehook that spring to the holes they originally were attached to. You shold be back to as good as new.
Hope this helps
Wg
