Square D breakers ok, in G.E. breaker box?
Old 05-31-02, 12:12 PM
Mnieft
Question Square D breakers ok, in G.E. breaker box?
Hi, recently had problem with a breaker that I needed to change out. When I went to get a replacement, I told them I had a G.E. breaker box with type-hom square D breakers installed. The man at the hardware store told me that square D breakers should not be installed in a G.E breaker box and it could cause arching. The house is only about 8 years old, I moved in a year ago. Will the square D breakers be ok? Or should I replace all of them with another brand? THANKS FOR ANY ADVICE!!!
Old 05-31-02, 09:54 PM
tinman1
Use whatever brand you want as long as they fit the buss, mounting bar and cover opening like the originals
Old 05-31-02, 10:04 PM
Received 1 Upvote on 1 Post
It's that "as long as" phrase that causes all the trouble. Sometimes breakers appear to fit, but don't really fit quite well enough. Make your panel and breakers match, by changing out one or the other. Are you really sure you have a GE box?
Old 05-31-02, 11:55 PM
Mnieft
It's for sure a G.E. box. Thanks for the replys!!
