eletrical outlets+++
Old 12-29-99, 10:41 AM
Angry
the outlets in two bedrooms are dead and when the circuit breaker is flipped on it switches right back off. According to the box the two rooms are connected to the same power source.
Old 12-29-99, 08:19 PM
Post
hi sigmajoe,
it apears to me that u have 1 of 2 conditions here eather u have a short circuit, or an over loaded circuit. unplug every thang thats on the circuit and try reseting the breaker. if it resets the circuit its self is fine. if it trips with nothing on it then u have a short in your wireing, and need to call your local electrician, if it holds plug in 1 at a time till it trips then remove that from the circuit and check it on another circuit if it trips that circuit as well then id say it has a short in it. if u have a lot pluged in on this circuit or a few high amp draw items like electric heaters or such then chances r u have an overload condition move some items to a diferent circuit.
