How do you check neutral wire
I've been trying to hang a ceiling fan on a vaulted ceiling, (tried 3 different fans) and can't get fan or light to work. Checked hot wite with a voltmeter and have power on the hot wire when tested with ground wire, but I don't know how to check the integrity of the neutral wire and can't check it visually since it is a vaulted ceiling. This is a new house and I suspect the neutral wire may have gotten stapled or otherwise damaged somehow.
Hi Keith.
OK.
You have in that ceiling box:
1 Bk, which should be connected to Bk from fan.
1 Red, which should be connected Bl from fan.
1 White, which should be connected to white from fan.
1 bare ground, which should be connected to ceiling box & green from fan.
Whith switches on, you should have 120V
between Blak - white, red - white.
You will have 120 V between ground and black or red.
Are the connections done in this way?
Regards Zoltan
P.S. If you have problem e-mail me at hz98@hotmail.com
